Problems with select
Smith, Gene
gene.smith at siemens.com
Mon Dec 6 23:38:11 UTC 2004
Camilo Alejandro Arboleda wrote, On 12/4/2004 12:34 PM:
> Chris Johns escribió:
>>Camilo Alejandro Arboleda wrote:
>>>I'm having trouble with select(). It returns -1, but the the
>>>networking is working fine. What can cause select() to return -1?
>>>I don´t know if there are any generic reasons for that, or it depends
>>>only on my code or both.
>>Select can return -1 on an error and errno is set appropriately.
>>What is errno set to ?
> It returns "Bad file number". Doing some debug i've found that the
> problem is not in select. The situation is:
> - I have two tasks, one for sending data and the other for receiving.
> - At some point the 'writing task' sends a packet, and then sends a
> 'FIN-ACK' packet, without returning error, or close() being called.
I assume the partner host did not initiate the close with a FIN first?
> Any idea?
