RTEMS and WEB services
    Cedric Aubert
    cedric_aubert at yahoo.fr
    Fri Feb 20 08:50:35 UTC 2004
I think it's possible but you should reimplement HTTP
protocol in your
application
to catch your XML information but for connection to
ISP and TCP/IP protocol
they are no problem with SH and ColdFire on RTEMS. Of
course, if I don't
make any mistake !!! :-)
I have only few month of RTEMS background. :-(
HTTP base protocol is not so complicated and should be
enought to do it
in your application, may be they are librairies on the
net but check the
license.
> -----Original Message-----
> From: silverio.di at qem.it [mailto:silverio.di at qem.it]
> Sent: Friday, February 20, 2004 9:37 AM
> To: cedric_aubert at yahoo.fr
> Cc: rtems-users at rtems.com
> Subject: Rif: RE: RTEMS and WEB services
> Thanks Mr.Cedric....
> I need to get an HTTP packet only for retrive an
> XML file which contain the informations for target.
> In few words I've a WebServer with SOAP service
> and I would connect a my target to an ISP and
between
> HTTP layer catch and send XML (SOAP formated) files
> to excenge data between taget and WebServer.
> Is possible have this configuration with RTEMS net
> libraries ? are this layers availables for SH
Hitachi &&||
> Motorola Coldfire CPUS ?
> Thank you again
>                       Cedric Aubert
>                       <cedric_aubert at ya        Per:
> silverio.di at qem.it, rtems-users at rtems.com
>                       hoo.fr>                  Cc:
Oggetto:  RE:
                      20/02/2004 08.56
>                       Per favore,
>                       rispondere a
>                       cedric_aubert
> Hi,
> As I can say, I don't see any impossibility here.
> See : http://www.rtems.com/features.html
> RTEMS support pppd to connect to your ISP. But I
never
> use it
> if someone can give more information like server or
> client side.
> But you should can connect to your ISP.
> RTEMS support have a stack TCP/IP (FreeBSD Port) so
no
> problem to
> send and receive TCP/IP packet trought the potential
> ppp connection.
> But to received HTTP packet you should have an
> application to do that.
> A webbrowser or may be your application receive this
> packet ?????
> RTEMS is only provided with a HTTP Server (httpd).
> But it still have some works about this look at :
http://www.rtems.com/ml/rtems-users/2004/january/msg00138.html
> Hope that help
> Cedric
> > Sent: Thursday, February 19, 2004 4:52 PM
> > To: rtems-users at rtems.com
> > Subject: RTEMS and WEB services
> > Hi to all,
> > sorry for my ignorance about but I would to ask
you
> if
> > RTEMS 4.6.0 (hitachi SH/Motorola Coldfile) could
be
> > connected to a WEB provider with a modem and then
> > access to HTTP protocol/services.
> > I've a target board and a cable Modem (56K) and I
> would to
> > connect this target to WEB how client and so
recover
> the
> > HTML contents of a my web page
> > Thank you for your instructions about
> > - [ ]Yes, is possible
> > - [ ] No, isn't possible
> > - This is the NET layers (protocols required)
> IP, xxx, yyy, yyy
> > - This is a draft image of the project .......
> > I've only to present a draft project so I need
> > simple and short instructions about that
> > thank you very much
> > Silverio DIquigiovanni
> __________________________________
> Do you Yahoo!?
> Yahoo! Mail SpamGuard - Read only the mail you want.
> http://antispam.yahoo.com/tools
Do you Yahoo!?
