RTEMS dyanmic RAM consumption
Chris Johns
cjohns at cybertec.com.au
Mon Jul 5 23:56:11 UTC 2004
Etienne Fortin wrote:
> Question: How much dynamic RAM do I need for
> 1) RTEMS (termsio, ethernet, clock, etc...)
Not sure about these.
> 2) TCP/IP stack
The TCP memory usage is for the internal structures for the stack, eg
the routes, interfaces and its various pieces of data. The stack also
uses memory for socket related data, and finally the mbuf pool. These
values all depend on the number of sockets, or the complexity of the
routing table. Typically the biggest user of memory is the mbuf pool.
This size effects the performance (you must send little bits of data at
a time) and the ability to handle large incoming bursts from faster more
powerful hosts.
> I'm afraid 64 KB may be short for all this. Is my impression correct?
Hard to say without knowing your requirements, but my impression is it
is not enough memory.
> Should I add some SDRAM to the system in case 64 KB is too small?
It would place less risk on your design.
Chris Johns
