More on MCF5307C3 - NE2000 network driver
gregory.menke at gsfc.nasa.gov
Wed Jul 7 14:55:47 UTC 2004
Chris Xenophontos writes:
> Hello,
> A few weeks ago, we had successfully (for the most part) integrated the
> NE2000 driver to the Coldfire MCF5307C3 Board Support package. We are able
> to send/receive application data through the network to our board. However,
> it appears that the either the receive or transmit daemon in ns8390.c quits
> after varying lengths of time. When that happens, ping times-out, and of
> course, no data is received/sent to the network. No other error messages
> are generated ( i.e, overflow, mbuf, ).
> We have tried hard-coding values for mbuf and mbuf clusters in
> rtems_bsdnet_config, using values up to 256K for mbufs, and 512K for mbuf
> clusters.
> CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS is currently set to 30. Increasing
> it to 40 doesnt help. NETWORK_TASK_PRIORITY is 80, and the priority of our
> application task that reads (blocks) on the socket is 220.
> Simply stopping and restarting the application, i.e, through the debugger
> will re-initialize the entire application, but the network remains
> unresponsive. To get the network application to respond again, we need to
> do a hard reset of the board.
> Is there some configuration parameter that Im missing?
> Thanks,
> Chris Xenophontos
> cxenophontos at hammers.com
Have you put printk's in the two daemons to see if they're waking up?
It sounds sort of like a deadlock with the network semaphore or
if_state.
Gregm
