More on MCF5307C3 - NE2000 network driver
Chris Xenophontos
cxenophontos at hammers.com
Wed Jul 7 20:18:25 UTC 2004
Thanks, Greg-
there are printf's, that indicate when the daemon wakes up(TX or RX
interrupt). I hooked up a scope, and noticed that when the network task
quits, the interrupt is no longer asserted by the DM9008 chip -- normally,
you can see IRQ3 pulse low, i.e, during network activity. When it quits,
IRQ3 no longer pulses but stays high.
Now I'm wondering if the ISR (ns8390_interrupt_handler) is getting trashed
or if the DM9008 chip is being reset somehow(??) and not generating the
interrupt. We have several boards that behave exactly the same with this
application.
thanks
cx
-----Original Message-----
From: gregory.menke at gsfc.nasa.gov [mailto:gregory.menke at gsfc.nasa.gov]
Sent: Wednesday, July 07, 2004 9:56 AM
To: Chris Xenophontos
Cc: rtems-users at rtems.com
Subject: More on MCF5307C3 - NE2000 network driver
Chris Xenophontos writes:
> Hello,
> A few weeks ago, we had successfully (for the most part) integrated the
> NE2000 driver to the Coldfire MCF5307C3 Board Support package. We are
able
> to send/receive application data through the network to our board.
However,
> it appears that the either the receive or transmit daemon in ns8390.c
quits
> after varying lengths of time. When that happens, ping times-out, and of
> course, no data is received/sent to the network. No other error messages
> are generated ( i.e, overflow, mbuf, ).
> We have tried hard-coding values for mbuf and mbuf clusters in
> rtems_bsdnet_config, using values up to 256K for mbufs, and 512K for mbuf
> clusters.
> CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS is currently set to 30.
Increasing
> it to 40 doesnt help. NETWORK_TASK_PRIORITY is 80, and the priority of
our
> application task that reads (blocks) on the socket is 220.
> Simply stopping and restarting the application, i.e, through the debugger
> will re-initialize the entire application, but the network remains
> unresponsive. To get the network application to respond again, we need
to
> do a hard reset of the board.
> Is there some configuration parameter that Im missing?
> Thanks,
> Chris Xenophontos
Have you put printk's in the two daemons to see if they're waking up?
It sounds sort of like a deadlock with the network semaphore or
if_state.
Gregm
