Connecting to FTPD with a Web Browser
Charles Steaderman
charlies at poliac.com
Thu Jun 3 19:08:37 UTC 2004
Steve Strobel wrote:
>At 12:21 AM 6/2/2004 -0700, Fernando RUIZ CASAS wrote:
>>On Sat, 29 May 2004 08:24:33 -0500, Charles Steaderman wrote:
>>>Quoting Steve Strobel <steve at link-comm.com>:
>>>Ideally, what I would like to do is use the GoAhead web server to provide a
>>>page that the user could connect to with his web browser. That page would
>>>have a link to get the latest firmware from our web site (so he could
>>>download it to his PC), then another button that would let him transfer that
>>>file to our unit using FTPD.
>>>Any advice will be greatly appreciated.
>>>Steve
>>>I use the syntax:
>>>ftp://username@192.168.0.24
>>>InternetExplorer will then prompt you for a password.
>>You have also a menu item posibility to 'login as' only if a ftp session is open
>>in Windows Internet explorer.
>>With this a cut & paste ftp session is opened without additional client software.
>>I use this to let up/download.
>>I don't know if rtems FTPD lets it but it seems that it hasn't reason.
>>BRGDS
>Thanks, Charles, for the syntax for a link that includes a username. Also to Fernando for the cut-and-paste tip using Windows Explorer. I think we are on the right track, but I have a few remaining problems:
>#1: While I can log on to the ftp server for our company's web page with the ftp://username@192.168.0.24 syntax, I can't seem to do the same to our embedded system running RTEMS. I _can_ log on to it with a command-line ftp client using any username (or a blank user name). I don't know what is different about the embedded FTP server that keeps it from working.
>#2: I can use Internet Explorer to paste files (causing an FTP upload), but I can't figure out how to copy files to the clipboard using it. I have to copy them to the clipboard using Windows Explorer before using IE to paste them. It seems like I should be able to follow one of those FTP links, right-click on a file and select copy, then navigate to a different directory and paste it. Am I missing something obvious?
If you mean that you want to copy a file FROM the FTP server to
somewhere local using IE, I believe that with some older versions of IE
you need to use the Edit->Copy to Folder... menu selection rather than
drag and drop. Perhaps this is the case for you.
>Thanks for your help,
>Steve
>!DSPAM:40bf704f295192128812037!
Charlie Steaderman
VP Engineering
Poliac Research Corporation
Phone: 952.707.6245
Cel: 612.242.6364
URL: <http://lists.rtems.org/pipermail/users/attachments/20040603/ab1ff5f3/attachment-0001.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20040603/ab1ff5f3/attachment-0001.vcf>
