Task Information from a Debugger
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Nov 16 14:41:37 UTC 2004
Leon Pollak wrote:
> On Tuesday 16 November 2004 15:29, you wrote:
>>Strange.  Running that macro I get:
>> # | Name |    ID    | Pri |  Ticks   | State
>> 1 | init | 0a010001 |   1 |     8067 | There is no member or method
>>named pc.
>>(gdb)
>>and that's it!  I should have 3 other tasks.  This occurs even before
>>the problem I mentioned previosly.  Does this mean I have something
>>configured incorrectly?
> Hmm... Very strange...
> It works fine for me for years...
> As far as I was able to understand, gdb does not see the Thread_Control
> structure definition.
> Do you have the debug information switched ON while compiling the RTEMS
> libraries? I never tried to use this without debug information, but I suppose
> that without it gdb does not know e\where to look for this structure...
There is a line which tries to print "thread_pc" and grabs something
out of the Registers structure.  This is not portable.
