RTEMS 4.6.2 BSP support
Ralf Corsepius
ralf_corsepius at rtems.org
Fri Oct 22 07:44:54 UTC 2004
On Fri, 2004-10-22 at 08:05, Thomas Doerfler wrote:
> Hello,
> apart from the comments of Joel and Ralf: Surely it
> is possible to extract the new BSPs from CVS and
> integrate them locally into the RTEMS 4.6.2 source
> tree, but this might require a lot of tinkering...
It does. Therefore, if you want them, start using RTEMS from CVS ;)
Of cause, things there are not as stable as with the releases, are much
more volatile, might also be temporarily broken, and are incompatible to
the releases, but ... this is what bleeding edge development sources are
for :-)
Ralf
