Makefiles
James Yates
j.yates at quartzuk.com
Mon Oct 25 15:42:29 UTC 2004
This is for RTEMS 4.6.0.
This would be a nice thing to have on a permanent basis. Inside my
makefile I have a CFLAGS+= line. When I added -O0 to it, my rtems app
seemed to fail to work. I didn't bother investigating this perhaps I
should have.
Can I then change CFLAGS+= to CFLAGS = and use completely different
flags in building the app to when I built RTEMS.
James
> -----Original Message-----
> From: Ralf Corsepius [mailto:ralf_corsepius at rtems.org]
> Sent: 25 October 2004 14:48
> To: James Yates
> Cc: RTEMS Users
> Subject: Re: Makefiles
> On Mon, 2004-10-25 at 15:18, James Yates wrote:
> > I am currently using RTEMS on a custom platform which is
> fully working
> > and I am very pleased with results.
> Which version of RTEMS are you using? The answer depends on
> which version you are using?
> > I have a problem though. I am
> > building my application and linking it against RTEMS and
> all is lovely.
> > However, my default CFLAGS has level 1 optimisation turned
> on, but I
> > want to compile a couple of source files with no optimisation. Can
> > anyone suggest how I can modify my makefiles to accomadate
> this since
> > the optimisation flag in CFLAGS comes from the BSP.
> I don't understand. Do you want your application or some
> parts of the source tree to be compiled with different flags?
> Do you want this change to be permanent or to be temporary (for
> testing/debugging)
> > I thought of
> > specifying, in my application makefile, something like a
> > NON_OPT_C_PIECES which could be compiled slightly
> differently, but I
> > am unsure about how to make the low level RTEMS makefile
> > infrastructure include this within the build. Can anyone help?
> Again, I don't understand.
> RTEMS application Makefile fragments only affect your applications.
> Settings in RTEMS make/custom/*.cfg affect RTEMS globally.
> Ralf
