RTEMS WIki On-Line
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Sep 23 17:30:27 UTC 2004
Hi,
RTEMS now has a Wiki.  It is at
http://www.rtems.com/phpwiki
Wikis are easy to use and edit.  This is critical since they
only work when a community contributes to them.
I would encourage people to read and add.  The structure is
based upon the current FAQ and some entries have been copied
over so far.  Important things you can contribute to:
+ RTEMS Applications - Add your application to the set at
http://www.rtems.com/phpwiki/index.php/RTEMSApplications
+ BSP Information - Help out by adding information on the BSPs
     you use.  Include the hints you wanted when you started.
http://www.rtems.com/phpwiki/index.php/BoardSupportPackageInformation
+ Personal Pages - Make yourself an account.  Your name becomes
   a Wiki page.  Include your experience level as:
     RTEMS Experience: YYYY+
   Include whatever you want about yourself that is technical. :)
Here's hoping this works out the way I hope.
