rtems on m5282lite
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Fri Apr 15 18:21:05 UTC 2005
g_YaneV wrote:
> Hello again,
> Problem solved.
> I insert this code in start.S just before the code that copy the new vector
> table.
> lea.l __IPSBAR+0xc08,a0
> move.l #0xfffffffe,(a0)
> lea.l __IPSBAR+0xc0c,a0
> move.l #0xffffffff,(a0)
> lea.l __IPSBAR+0xd08,a0
> lea.l __IPSBAR+0xd0c,a0
> This way I am sure that all interrupts are unmasked by rtems code. Isn't this
> a good practice in general(no one can know what is running befor calling
> rtems). My problem was that dBUG allows one timer and rtems after that allows
> another.
Do you mean masked or unmasked? All interrupt sources should be cleared
and disabled before rtems_initialize_executive is executed. RTEMS
enables CPU interrupts when switching to the first task/thread so you
don't want any spurious interrupt sources outstanding.
> thanks for showing me where the problem can be.
joel at OARcorp.com On-Line Applications Research
