libcsupport question ( about tcflush.c )
    Jennifer Averett
    jennifer.averett at oarcorp.com
    Fri Aug 26 14:11:30 UTC 2005
fflush works and is used in the test examples.  I've never used tcflush,
but you will submit a PR against the filesystem I'll take a stab at it
when I get a chance.
Jennifer
> Hi,
> In /rtems-4.6.2/cpukit/libcsupport/tcflush.c, the tcflush fonction do
> nothing (  it return 0 only ).
> I use a custom BSP based upon mcf5206elite, actually that is a problem
> because I need to flush
> the console ( in and out ) for my application.
> Must I implement this function myself ?
> Or other way is needed ?
> Thanks a lot.
> -Stan
