No rule to make target `new-exceptions/cpu.c'
Ralf Corsepius ralf.corsepius at rtems.org
Wed Feb 23 17:58:33 UTC 2005
On Wed, 2005-02-23 at 11:59 -0500, Peter Dufault wrote:
> I've gone through the configuration and build on Fedora 3 now as well
> as FreeBSD.  When I try to build psim (or mvme5500, which is what I
> eventually want to get to) on both systems it eventually stops with:
> *** No rule to make target `new-exceptions/cpu.c', needed by
> `new-exceptions/new_exceptions_rtems_cpu_rel-cpu.o'.  Stop.
> The configuration I'm using is:
> ../rtems4.7/configure
> --target=powerpc-rtems
> --enable-maintainer-mode
> --prefix=/opt/rtems-4.7
> --disable-posix
> --disable-networking
> --disable-cxx
> --disable-multilib
> and the behavior is the same whether I add "--enable-rtemsbsp=psim" or
> leave it out and do make RTEMS_BSP=psim.
As I already outlined on PM, some exception-related directories have
been moved in CVS. Therefore the information you are providing is
insufficent to be answered.
Most probably you need to
cvs up -dP
./bootstrap -c
./bootstrap
Also, make sure to have the patch attached to PR 546 applied to your
auto, and make sure to have /opt/rtems-4.7/bin at the beginning of your
$PATH.
> Since there has been a lot of discussion of new-exceptions, can someone
> verify that psim should build OK if I've got things configured
> correctly?
Yes, 100s of times.
Ralf
