Help needed using i386-rtems-gcc
joe gard joe_os2001 at hotmail.com
Thu Jan 6 16:47:42 UTC 2005
thank you in first place,
unfortunatly it doesn´t help me. I have a rtems app that I want to put to
work in the real world. So I want to compile it without eny debug info, in
order to get a app targeted for speed at the maximum. So I have to compile
it without debug info right?
How Do I do that is I use the make file of the hello world sample? this make
file calls the i386-rtems-cc which ises always the -g option. I need to
remove it but I dont know where is the -g option configured to remove it...
By other side rtems app is linked to the kernel, right? So I also have to
compile the kernel in "release" mode, right?  how do I do that if I use the
make all install to compile the kernel?
The ask is this:  Which is the standar method to release a rtems app to the
real world in terms of release version?
Many thanks
Joe
>From: "Thomas Doerfler" <Thomas.Doerfler at imd-systems.de>
>To: "joe gard" <joe_os2001 at hotmail.com>
>Subject: Re: Help needed using i386-rtems-gcc
>Date: Wed, 05 Jan 2005 20:54:48 +0100
>Joe,
>the make file infrastructure for RTEMS is quite complicated, so
>I would leave it as it is.
>If you need an executable without symbol/debug information, you
>might use the GNU tool
>i386-rtems-strip -S <filename>
>does this help you?
>wkr,
>Thomas.
> > Hi!
> > I would like to compile the hello world sample in release version, that
> > is, without any debug information, targeted to i686 as always.
> > So, I have to remeve the -g Wall flags right, but where is the file
> > where this flag is?
> > The make file of the hello world sample doenst include these flags I
> > already search in other conf files but I cant see the flat in order to
> > remove it...
> > Can someone tell me how do I turn off the debug info in the target
> > executable?
> > Many thanks
> > Joe
> > _________________________________________________________________
> > Express yourself instantly with MSN Messenger! Download today it's FREE!
> > http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
>IMD Ingenieurbuero fuer Microcomputertechnik
>Thomas Doerfler           Herbststrasse 8
>D-82178 Puchheim          Germany
>email:    Thomas.Doerfler at imd-systems.de
>PGP public key available at: http://www.imd-
>systems.de/pgp_keys.htm
FREE pop-up blocking with the new MSN Toolbar - get it now!
http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
