I386-PC586 on Dil/NetPC
Chris Johns
chrisj at rtems.org
Wed Jun 22 00:38:07 UTC 2005
Valentin Buergel wrote:
> I am new to RTEMS. I successfully build and installed RTEMS for the i368
> hardware. But I am not able to run the hello.exe application on the embedded
> hardware.
I assume this is the pc386 BSP.
> There is no video therefore I enabled RTEMS_RUNTIME_CONSOLE_SELECT in
> console.c. I also adapted iqr.h to fit COM2 (IRQ11 instead of 3). RS232 is
> connected on COM1 and COM2 and I watch on minicomm but nothing happens.
Did you also change BSP_CONSOLE_PORT_CONSOLE in bsp.h ?
> The last thing I see from GRUB is:
> # Booting 'Hello-World'
> # kernel (hd1,1)/hello.exe
> # [Multiboot-elf, <0x100000:0x1d584:0x2e48>, shtab=0x121140, entry=0x10000c]
This looks fine.
Chris Johns
