MVME5500 status, and on to PMC interrupts
Peter Dufault
dufault at hda.com
Tue Mar 1 13:32:49 UTC 2005
On Mar 1, 2005, at 7:00 AM, Peter Dufault wrote:
> I'll send a summary in a little while after I go over the code to see
> what it is doing and what it isn't.
Here's an ASCII art sketch.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20050301/4749d82a/attachment-0001.txt>
The numbers in parenthesis are the PCI bus/slot/function codes, beneath
them are the assignments for PCI IRQA,B,C,D. Note that the VME
interface and the PMCSPAN slots do share interrupts.
Here's my take on what's up. I'm not a PCI expert, so don't be
surprised if I'm wrong.
The current code in mvme5500/pci doesn't do any bridge discovery or
setup, and neither does the MOTBoot boot code. I plan to change the
code in mvme5500/pci to setup the PMCSPAN bridge, but not to do any
general fix. Since a PMCSLOT could have a device with a PCI bridge in
it this is only a stopgap.
I think what has to happen long-term is to setup the two busses using
the code in powerpc/shared/pci, only keeping the "PCIX" stuff in
mvme5500 (the code that needs to know about the two separate busses)
and calling into the shared PCI code for the bus discovery and setup.
That code will also need to twiddle the INT numbers returned from the
shared code to go from PCI interrupts to the way they feed into the
mvme5500 board.
Peter
Peter Dufault
HD Associates, Inc.
