How to mask IRQ
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Tue May 31 17:34:11 UTC 2005
Leon,
I had a look into the mbx8xx BSP irq handler code as an example. At a
first glance I would say, that no API extension would be needed to
achive your functionality, but the current implementation would need
some modifications.
You already have the two calls:
int BSP_install_rtems_irq_handler  (const rtems_irq_connect_data* irq);
int BSP_remove_rtems_irq_handler  (const rtems_irq_connect_data* irq);
and
int BSP_get_current_rtems_irq_handler	(rtems_irq_connect_data* irq);
Currently, I think, it is not yet safe to call
"BSP_remove_rtems_irq_handler" from an ISR, but I think with some
careful tinkering it could be made safe.
Would this be ok for your requirements?
wkr,
Thomas.
leonp at plris.com schrieb:
> On Tuesday, 31 בMay 2005 16:17, Thomas Doerfler wrote:
>>I think the initial request from Leon should be considered, to extend
>>the "new exception processing" API with some means to disable/enable
>>certain interrupt controller inputs either from application level (well,
>>we already have that, I think) or from within an interrupt handler. IMHO
>> it would be nice if any interrupt handler can enable/disable the
>>request input of any other interrupt source, therefore I would recommend
>>not to use a special return value to manage this, but function calls to
>>manage this.
>>Any comments?
> I also think in your stream. And I also should like to have some API function
> to do this. The only reason that I suggested the return code is, that
> functions will require intermediate variable, which in turn requires very
> carefull attitude as it may be changed/restored in two nested calls, while
> the return value seems to be simple and safe.
> Thanks.
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
     http://www.imd-systems.de/pgp_keys.html
