How to mask IRQ
Eric Valette
eric.valette at free.fr
Sun May 29 12:42:54 UTC 2005
leonp at plris.com wrote:
> I need to mask, for example, IRQ5 interrupt from within the ISR.
You mean while handling another IRQ (e.g IRQ 4) I guess?
> Today's implementation seems not to allow this operation, as the ISR is
> called from the IRQ dispatcher, which restores the mask state to the value it
> saved before the ISR was called.
> The most simple decision I see, is to return the desired mask as a return
> value from the ISR function. Thus, the dispatcher must check that the ISR
> return value is not zero.
In the MPC860, there is a way to mask automatically other interrupts
when a dedicated interrupt occur (at least at the CPM level) I do not
remember for the SIU. Its from memory as I do not have the source handy...
In theory, the masks in the interrupt controller enables to define a set
of interrupt blocked on a per irq basis. Check the sources I think there
is a mask somewhere...
__
/ ` Eric Valette
/-- __ o _. 6 rue Paul Le Flem
(___, / (_(_(__ 35740 Pace
Tel: +33 (0)2 99 85 26 76 Fax: +33 (0)2 99 85 26 76
E-mail: eric.valette at free.fr
