PCI caching question related to mvme5500
gregory.menke at gsfc.nasa.gov
Tue Nov 1 18:20:01 UTC 2005
Peter Dufault writes:
> On Nov 1, 2005, at 11:29 AM, gregory.menke at gsfc.nasa.gov wrote:
> > OTOH, maybe the board has an internal buffer that it fills w/ data and
> > making that part cacheable might expedite copying it off the
> > board. But
> > I think the OP would be better served by using DMA- my impression
> > being
> > its plain PIO right now, which can cut throughput on the PCI bus by a
> > factor of 6.
> The board has a double-buffered region mapped onto the bus. When the
> data is ready I invalidate the cache every cache line and then memcpy
> the data off. Without reading through a cached region the CPU won't
> prefetch and the throughput is terrible. With it you should be able
> to run at PCI memory speed.
> There are many situations, e.g. small frame sizes as in this case,
> where I'd rather have prefetch (and posted writes for output) than DMA.
> Peter
This is essentially PIO mode, the slowest possible way of getting data
off the PCI bus. If you're lucky it may burst but you can't confirm
that without a bus analyzer. This is very likely why you're having
performance issues. Its cutting your bus throughput by about a factor
of 6. You should consider using DMA to get your data off the board.
Gregm
