MVME5500 board support status?
Ralf Corsepius ralf.corsepius at rtems.org
Thu Oct 27 15:57:04 UTC 2005
On Thu, 2005-10-27 at 11:35 -0400, Peter Dufault wrote:
> On Oct 27, 2005, at 7:29 AM, Joel Sherrill wrote:
> > So has someone actually tried a gcc 4.0.x with the mvme5500?
> > Most BSPs have worked fine with gcc 4.0.x but a few have been
> > optimized into breaking. :)
> > --joel
> Yes, I've done all my mvme5500 work with 4.0.x.  It was one of the
> BSPS that was optimized into breaking...
> But I haven't updated from CVS in a long time.
> I'm currently trying to get the cvs head on Solaris, but at a very
> low level since other things keep getting in the way.  The last thing
> I got was "powerpc-rtems-gcc: new-exceptions/cpu_asm.o: No such file
> or directory" building RTEMS even though I'm using:
You probably haven't applied the RTEMS patch to automake.
> autoconf 2.59-4
> autoheader 2.59-4
> autom4te-2.59-4
> automake 1.9.6-0
> aclocal 1.9.6-0
> RTEMS 4.6.99
> Binutils 2.16.1
> GCC 4.0.2
> newlib 1.13.0
Vanilla 1.13.0 won't work, as well as newlib-cvs currently doesn't work
for some target (I am not sure about the powerpc).
=> You also need the newlib RTEMS patches.
Ralf
