New version of GDB Macros file
Paul Whitfield
paulw at omnitronics.com.au
Wed Aug 2 07:49:45 UTC 2006
Joel Sherrill wrote:
> Hi,
> I have been tinkering for a while with the set of gdb user defined
> commands and am ready to post a new version. I think it is a
> significant improvement over previous iterations. It now knows
> about more object classes including:
> + Classic API semaphores,
> + Classic API message queues
> + Classic API regions
> + POSIX API semaphores
> + POSIX API mutexes
> + POSIX API message queues
> It can now display the set of tasks waiting on a thread queue
> as well as information on the C program heap and RTEMS Workspace.
> There are utilities to print the timer delta chain and to do
> some basic checks on dispatching critical sections and ISR nest
> level consistency. All in all, there are now about 25 documented
> commands and it should be more clear on how to add more.
> Until we figure out how to incorporate it in a more accessible
> fashion, it is still at:
> http://www.rtems.com/wiki/index.php/GdbScripts
> And is attached to this email for posterity.
> FWIW gdb user defined commands are not that hard to write. If you
> find yourself chasing an RTEMS data structure, please write a new
> command and add it to the set. It really helps us all in the long
> run.
Hi Joel / All,
I would like to make use of these macro's as I am chasing down a
difficult to find uart bug.
However, I am doing something wrong as I can not get them to work for
me.
I am using RTEMS 4.6.5 on Coldfire.
Gdb version is 6.0
It appears that gdb does not understand the definition of the
Thread_Control structure.
Any attempt to cast a pointer in gdb fails with the same
message.
Any suggests as to what I can do to fix this?
Regards
Paul.
Example output:
(gdb) rtems_check_state
RTEMS System State is:
$5 = SYSTEM_STATE_UP
NOT inside dispatching critical section
NOT inside an ISR
(gdb) rtems_classic_tasks
# | Name | ID | Pri | Ticks | State
No symbol "Thread_Control" in current context.
(gdb)(gdb) rtems_classic_message_queue 1
1 | LCDQ | 22010001 | 0/10 msgs FIFO - No symbol "Thread_Control" in
current
context.
(gdb)
The information in this e-mail is intended for the addressee only.
Unauthorised use, copying, disclosure or distribution by anyone else
is prohibited. Please let us know immediately if you receive this
e-mail in error. Thank you.
