Strange error while building binutils
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Aug 2 13:23:19 UTC 2006
If I recall correctly, gcc 3.4 was the first gcc release series to
tighten up
pointer checks. binutils 2.13.2.1 is older than gcc 3.4 and probably
has numerous places gcc doesn't like. I know for the Linux binaries,
they are built on a chroot'ed RH73 environment.
--joel
Paul Whitfield wrote:
> Ali Asgar Nasir wrote:
>> binutils-2.13.2.1
>> rtems 4.6.6
>> command line used for configuring binutils
>> configure --target=m68-rtems --prefix=/rtems-docs4.6.6
>> command line used for building
>> make all
>> make info
>> make install
>> i get the error when i give the make all command.
> The first obvious mistake is that the target argument should be
> --target=m68k-rtems
> Have you read and understood the instructions for how to build the
> tools set at:
> http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.6/share/rtems/html/started/started00030.html
> I recommend following the directions give as closely as possible.
> Regards
> Paul
> The information in this e-mail is intended for the addressee only.
> Unauthorised use, copying, disclosure or distribution by anyone else
> is prohibited. Please let us know immediately if you receive this
> e-mail in error. Thank you.
