New version of GDB Macros file
Greg Marsden
Greg.Marsden at l-3com.com
Wed Aug 2 11:51:38 UTC 2006
I replaced them with (struct Thread_Control_struct *) and they work
fine with PPC rtems.
- Greg
Paul Whitfield wrote:
> Joel Sherrill wrote:
>> Hi,
>> I have been tinkering for a while with the set of gdb user defined
>> commands and am ready to post a new version. I think it is a
>> significant improvement over previous iterations. It now knows
>> about more object classes including:
>> + Classic API semaphores,
>> + Classic API message queues
>> + Classic API regions
>> + POSIX API semaphores
>> + POSIX API mutexes
>> + POSIX API message queues
>> It can now display the set of tasks waiting on a thread queue
>> as well as information on the C program heap and RTEMS Workspace.
>> There are utilities to print the timer delta chain and to do
>> some basic checks on dispatching critical sections and ISR nest
>> level consistency. All in all, there are now about 25 documented
>> commands and it should be more clear on how to add more.
>> Until we figure out how to incorporate it in a more accessible
>> fashion, it is still at:
>> http://www.rtems.com/wiki/index.php/GdbScripts
>> And is attached to this email for posterity.
>> FWIW gdb user defined commands are not that hard to write. If you
>> find yourself chasing an RTEMS data structure, please write a new
>> command and add it to the set. It really helps us all in the long
>> run.
> Hi Joel / All,
> I would like to make use of these macro's as I am chasing down a
> difficult to find uart bug.
> However, I am doing something wrong as I can not get them to work for
> me.
> I am using RTEMS 4.6.5 on Coldfire.
> Gdb version is 6.0
> It appears that gdb does not understand the definition of the
> Thread_Control structure.
> Any attempt to cast a pointer in gdb fails with the same
> message.
> Any suggests as to what I can do to fix this?
> Regards
> Paul.
> Example output:
> (gdb) rtems_check_state
> RTEMS System State is:
> $5 = SYSTEM_STATE_UP
> NOT inside dispatching critical section
> NOT inside an ISR
> (gdb) rtems_classic_tasks
> # | Name | ID | Pri | Ticks | State
> No symbol "Thread_Control" in current context.
> (gdb)(gdb) rtems_classic_message_queue 1
> 1 | LCDQ | 22010001 | 0/10 msgs FIFO - No symbol "Thread_Control"
> in current
> context.
> (gdb)
> The information in this e-mail is intended for the addressee only.
> Unauthorised use, copying, disclosure or distribution by anyone else
> is prohibited. Please let us know immediately if you receive this
> e-mail in error. Thank you.
