possible SPARC cpu_asm.S error
Jiri Gaisler jiri at gaisler.com
Tue Aug 15 16:17:26 UTC 2006
Jerry Needell wrote:
> What about the section at the end of ISR_Dispatch? Don't we have to have
> the nop's before the jmp? good_task_window:
>        mov     %l0, %psr                  !  **** DISABLE TRAPS ****
>        nop; nop; nop;                     ! Need three nops for pipeline
>                                           !  and restore condition codes.
>        ld      [%g1 + ISF_G1_OFFSET], %g1 ! restore g1
>        jmp     %l1                        ! transfer control and
>        rett    %l2                        ! go back to tasks window
> This is where I thought my problem was occuring. I added the otheres
> just to be safe.
Yes, you will need to add the three nops to this sequence.
In fact, this sequence is very fragile and depends on the
assumption that the user's interrupt handler returns with
the same window pointer (psr.cwp) as it was called with.
I am note sure this assumption is true in all case (especially
with nested interrupts) but it seems to work somehow. The
problem you have seen is probably due to an interrupt occuring
between the first insruction (mov %l0, %psr) and any of the
three following.
Also the last sequence is dubious:
good_task_window:
and might need three nops to work under all conditions.
Jiri.
>> Do you have a test program that triggers the error? I have used
>> the rtems-ttcp networking program and sent large ping floods to
>> generate many interrupts, but I saw no crash.
> I am trying to isolate a good example. It is hard because it seems to go
> away when I "think" I have found the error.
>> Regarding the -mv8 option to leon3, it should not be made default.
>> There are leon3 systems without hardware mul/div for which this
>> option will not work. The kernel does not do a lot of multiplication,
>> so the -mv8 should only be used when compiling applications, not
>> the kernel.
> I agree! I only added this as an example of what I was doing.
> - Jerry
>> Jiri.
>>> I think I have found an error in the cpukit/score/cpu/sparc/cpu_asm.S
>>> code. When writing to the PSR, a sequence of three NOP's must be added
>>> to ensure that the PSR value is properly set after running through the
>>> pipeline. This is done in most places in cpu_asm.S but was left out in a
>>> few and, I think, causing me some problems. I have been trying to track
>>> down and intermittent crash for a long time! My application was crashing
>>> after servicing an interrupt. cpu_asm.S includes ISR_Dispatch which was
>>> missing the NOP's ater setting the PSR before returning.
>>>   The problem became much worse when I tried rebuilding 4.6.99.3 using
>>> the -mcpu-v8 flag to take advantage of the SPARC V8 multiply in the
>>> LEON3.  The  diff attached also  has the change I made to
>>> make/custom/leon3.cfg to set the -mcpu=v8 switch.            The
>>> cpu-asm.S error should apply to all SPARC cpu's (v7 or v8).
>>> - Jerry
>>> Index: cpukit/score/cpu/sparc/cpu_asm.S
>>> RCS file: /usr1/CVS/rtems/cpukit/score/cpu/sparc/cpu_asm.S,v
>>> retrieving revision 1.11
>>> diff -u -r1.11 cpu_asm.S
>>> --- cpukit/score/cpu/sparc/cpu_asm.S    1 Apr 2004 10:12:49 -0000
>>> 1.11
>>> +++ cpukit/score/cpu/sparc/cpu_asm.S    15 Aug 2006 11:47:40 -0000
>>> @@ -212,6 +212,7 @@
>>>         andn    %g1, SPARC_PSR_ET_MASK | SPARC_PSR_CWP_MASK, %g1
>>>         or      %g1, %g3, %g1                 ! g1 = heirs psr
>>>         mov     %g1, %psr                     ! restore status
>>> register and
>>> +    nop; nop; nop;                  ! Need three nops for pipeline
>>>         mov     %wim, %g2                     ! g2 = wim
>>>         mov     1, %g4
>>> @@ -605,6 +606,7 @@
>>>          *  Decrement ISR nest level and Thread dispatch disable level.
>>> @@ -798,6 +800,7 @@
>>> good_task_window:
>>> codes.
>>> Index: make/custom/leon3.cfg
>>> RCS file: /usr1/CVS/rtems/make/custom/leon3.cfg,v
>>> retrieving revision 1.2
>>> diff -u -r1.2 leon3.cfg
>>> --- make/custom/leon3.cfg    9 Jan 2006 15:09:55 -0000    1.2
>>> +++ make/custom/leon3.cfg    15 Aug 2006 11:47:41 -0000
>>> @@ -20,7 +20,7 @@
>>> # CPU_CFLAGS = -mno-v8 -mcypress $(MSOFT_FLOAT)
>>> #     -mcpu=cypress says to optimize for a Cypress 60x chipset
>>> #CPU_CFLAGS = -mcpu=cypress $(MSOFT_FLOAT)
>>> -CPU_CFLAGS = -mcpu=cypress -msoft-float
>>> +CPU_CFLAGS = -mcpu=v8 -msoft-float
>>> # optimize flag: typically -0, could use -O4 or -fast
>>> # -O4 is ok for RTEMS
