pc386 on head .. explanation
Joel Sherrill
joel.sherrill at oarcorp.com
Tue Jan 31 15:30:57 UTC 2006
Hi,
I don't know what is causing this but the stack usage
has apparently increased with newer gcc versions. I
increased the stacks in ticker until it would run.
Here is the stack usage report:
Stack usage by thread
ID NAME LOW HIGH AVAILABLE USED
0x09010001 IDLE 0x0012b3e0 0x0012b7df 1008 128
0x0a010002 TA1 0x0012c2a4 0x0012cea3 3056 2496
0x0a010003 TA2 0x0012d408 0x0012e007 3056 2400
0x0a010004 TA3 0x0012e56c 0x0012f16b 3056 2400
0xffffffff INTR 0x001289cc 0x001299cb 4080 172
I don't think ticker is particularly abusive of the stack.
Does anyone have any thoughts on why we are using over
2K of stack per task. Neither IDLE not the INTR stack
appear to be a problem.
I have run it with gcc-head and gcc 4.0.1 RPMs.
--joel
