Help for hello_world!
Karel Gardas
kgardas at objectsecurity.com
Tue Jan 31 09:20:57 UTC 2006
On Tue, 31 Jan 2006, Matteo wrote:
> Hi
> I have installed rtems4.6.99.2 with gcc4.02,binutils2.16.1,newlib1.13.0.
> My system is a ubuntu and I have intel Centrino. I have configured rtems, gcc
> and binutils for a target=i386 and rtemsbsp=pc386.
> I download example4.6.99.2, I export RTEMS_MAKEFILE_PATH and I make
> hello_world and it creates ./o-optimize
> directory where there are six files; hello.bin, hello.bt, hello.exe, hello.num,
> hello.obj, test.o .
> When I try to launch /.hello.exe like following;
> /usr/local/rtems/source/tools/examples4.6.99.2/hello_world_c/o-
> optimize#./hello.exe
> Killed
> :/usr/local/rtems/source/tools/examples4.6.99.2/hello_world_c/o-optimize#
> Why Killed?
> I'm a root and my shell is a bash.
> Someone can help me?
Yes, does Ubuntu uses GRUB? If so, copy hello.exe to the directory where
you have your linux kernel binaries, reboot, instruct grub to boot
hello.exe, boot it.
Do you see it running? Please keep in mind that RTEMS is standalone RTOS
and all BSPs except unix/posix provides binaries which are intended to be
boot on the target board/device. The only unix/posix BSP compiles RTEMS
apps into ordinary Unix apps which might be then run on top of Unix/Linux.
Cheers,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
