Coldfire questions
Alan Cudmore
Alan.P.Cudmore at nasa.gov
Tue Jan 10 16:25:42 UTC 2006
I downloaded this coldfire-0.3.0 simulator and tried it out. I got
one of the standard uClinux ports to run on it, so my setup works.
Next, I built the RTEMS 4.6.2 mcf5206elite BSP to try it with the
"lite-5206e" simulator configuration. It looks like the simulator
download command is assuming a certain memory address for the
download ( DL ) command. It wants to load the code at 0x10000, but
the RTEMS BSP is targeting the RAM for 0x30000000. ( which is the
correct range for the real board )
To make it work, I think we would have to tweak the simulator to load
the code to the correct memory range.
I think I missed this, but does the SkyEye simulator support the
coldfire architecture?
Alan
On Jan 9, 2006, at 2:44 PM, Joel Sherrill wrote:
> Karel Gardas wrote:
>> On Mon, 9 Jan 2006, Joel Sherrill <joel at OARcorp.com> wrote:
>>> Karel Gardas wrote:
>>>> Hi,
>>>> IMHO lite-5206e.board from the simulator might support
>>>> mcf5206elite BSP.
>>> is this only at the original source for the coldfire simulator?
>> I'm refering to: http://www.slicer.ca/coldfire/files/
>> coldfire-0.3.0.tar.gz
>> SkyEye integration might be buggy as it is quite new...
> OK.. I have built it and can invoke it as
> ../coldfire --board=lite-5206e
> But I don't see how to download. The instructions on the page talk
> about telnet'ing to two ports and then entering the dl command but I
> don't see how that would work. Am I being stupid?
>>> Looking at the source, I see that this file arch/coldfire/common/
>>> board.c
>>> has what appears to be a hook for the Arnewsh board but I don't
>>> see any obvious way to configure it.
>>> FWIW .. why does this take gtk2-xll to build? I have only run
>>> SkyEye as a command line program.
>> gtk2 is used for LCD emulation.
> OK. Then I am not missing any fancy features. :)
> --joel
