Problem to save file on the hard disk! What I have to set to do it ?
    Matteo
    matteo.posterli at studenti.unipr.it
    Mon Mar 13 17:15:45 UTC 2006
Ok this is the result of the command "fdisk -l /dev/hda"
Disk /dev/hda: 40.0 GB, 40007761920 bytes
255 heads, 63 sectors/track, 4864 cylinders
Units = cilindri of 16065 * 512 = 8225280 bytes
Dispositivo Boot      Start         End      Blocks   Id  System
/dev/hda1            2678        3014     2706952+  83  Linux
/dev/hda2               1        2677    21502971    c  W95 FAT32 (LBA)
/dev/hda3            3015        4784    14217525   83  Linux
/dev/hda4            4785        4864      642600    5  Esteso
/dev/hda5            4785        4864      642568+  82  Linux swap / Solaris
looking with gparted I have the result that, hda1 is "FAT16", hda2 is "FAT32",
hda3 is "ext3", hda4 is "exetended", hda5 is "linux swap".
I created hda1 with FAT16 thinking to resolve the problem, but from the fileio
example I have always the same error,
" fsmount: mounting of "/dev/hda1" to "/mnt/hda1" failed: No such file or
directory " but now hda1 is FAT16 so it could be right for RTEMS, but it isn't.
Why ?
Can you help me ?
Thanks advanced
MAtteo
Scrive "Thomas Doerfler (nt)" <Thomas.Doerfler at imd-systems.de>:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Matteo,
> Matteo schrieb:
> > Ok hda3 is "ext3", but I have a window "FAT" on hda1 and hda2, so I could
> save
> > my file in this partitions?
> yes, this should be possible.
> > But I see from the error message that RTEMS can't mount all my partition
> hda1,2
> > (FAT) for windows and hda3,4 (ext3) for linux.
> can you boot linux on your system, log in as root and send me the output
> of the command   "fdisk -l /dev/hda" ? Maybe the type of your FAT
> partitions is ounknown to RTES or your FAT partitions are located in an
> extended partition (most unlikely).
> > Can you help to save a file in one of this partitions ?
> > Is there any way to save on a "ext3" partitions ?(Because I have to test
> RTEMS
> > on some linux systems and I'm afraid they are all "ext3"!)
> Currently there is no RTEMS support for ext3 filesystems, so sorry, this
> will not work.
> wkr,
> Thomas.
> > Matteo,
> > well, it SHOUDL work, if you have a FAT partition in the primary
> > partition table of your harddisk.
> > You are mentioning havong Linux on hda3, most problable it will use
> > "ext3" as the filesystem, and RTEMS does not know this FS type.
> > When you are running Linux on your system, what kind of output do you
> > get from the command
> > fdisk -l /dev/hda
> > (you have to run this as root).
> > wkr,
> > Thomas.
> > Matteo schrieb:
> >>Ok, like you have suggested I understood the steps to mount the hardisk,
> > but
> >>the problem is that the fileio example doesn't mount my hardisk!
> >>I follow the steps suggest from the fileio.doc but after it asks to me to
> > enter
> >>the partition table of first harddisk ( /dev/hda ) I try to mount the
> >>partitions and I have an error, He says to me
> >>directory "  and so on for hda2,3,4 and for hdc1,2,3,4
> >>Linux partition is on hda3, but the fileio example doesn't mount it !
> >>What's the problem ?
> >>Have you some idea ?
> >>Really Thanks in advance
> >>Matteo
> >>Matteo,
> >>I assume you are working on a standard i386 pc hardware. Have a look at
> >>the "fileio" sample application available in the RTEMS source tree under
> >>"cpukit/testsuites/samples/fileio". You should try to get it working on
> >>your system (it should work from scratch if you got a standard PC system).
> >>Have a look at "fileio.doc", it explains a bit what should work with
> >>this sample program.
> >>In your application, you will have to do the following steps to get
> >>access to your harddisk:
> >>- add the IDE and ATA drivers to your standard driver table (see entries
> >>in fileio/system.h)
> >>- add a rtems_bdbuf_configuration data structure to your system (once
> >>again, see fileio/system.h)
> >>- add a fs_table to your application, which specifies which harddisk
> >>partitions are to be mounted to which mount points (see fileio/
> >>- call the "rtems_ide_part_table_initialize" function after system
> >>startup to read in your harddisk partition table. This call will create
> >>a new device node (/dev/hda1 ...) for each partition available.
> >>- call the "rtems_fsmount" function to mount the partitions to their
> >>respective mount points. Have a look into "libmisc/fsmount" to find out,
> >>how it works.
> >>Then you can access the harddisk partitions at their respective mount
> >>points.
> >>wkr,
> >>Thomas.
> >>Matteo schrieb:
> >>>Hi
> >>>Joe says to me ask you how I can save a file on hard disk? if I have to
> > set
> >>>something in my linux's grub?
> >>>below the previous email sent to Joel.
> >>>Thanks in advance
> >>>Matteo
> >>>Scrive Joel Sherrill <joel.sherrill at oarcorp.com>:
> >>>>Matteo wrote:
> >>>>>Hi
> >>>>>I'm trying to use the fdopen example of the package example-4.6.99.2
> but
> >>it
> >>>>>doesn't works, It doesn't create the file!
> >>>>I could be wrong but I think this one actually was submitted as part of
> >>>>a bug report and
> >>>>the bug may still be outstanding.  It may be fixed.  I just don't
> >>>>remember.  See below for
> >>>>the more likely case.
> >>>>>But I can launch the hello world example and I create some simple posix
> >>>>program
> >>>>>with rtems yet so I think to have configured it well.
> >>>>>So what can be the problem ?
> >>>>>May be when I launch the fdopen example I have to set some particular
> >>>>privilege
> >>>>>in the "grub"(my linux boot loader) to allow it to write on the hard
> >>disk?
> >>>>this
> >>>>>is only my newbye's opinion..
> >>>>Ohh.... if you are doing anything with the hard disk, then there is some
> >>>>filesystem specific
> >>>>configuration to get things right.  The example code is only going to
> >>>>work with the IMFS
> >>>>which is a RAM based filesystem.
> >>>>Ask on the list so someone list Thomas can point you to an example
> setup.
> >>>>>Thanks in advantage
> >>>>>Matteo
> >>IMD Ingenieurbuero fuer Microcomputertechnik
> >>Thomas Doerfler           Herbststrasse 8
> >>D-82178 Puchheim          Germany
> >>email:    Thomas.Doerfler at imd-systems.de
> >>PGP public key available at:
> >>     http://www.imd-systems.de/pgpkey_en.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.5 (MingW32)
> Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
> iD8DBQFEFRlZwHyg4bDtfjQRAgTlAJ472DyQwiSko7pkJ8o+1kbj420bFACgmSRL
> Avt5JxDt/FuRSa0BBSbO2rA=
> =C1K0
> -----END PGP SIGNATURE-----
