Problem to save file on the hard disk! What I have to set to do it ?
    Thomas Doerfler (nt)
    Thomas.Doerfler at imd-systems.de
    Mon Mar 13 18:50:03 UTC 2006
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Matteo,
I am a bit confused, your listing shows, that /dev/hda1 is a Linux ext3
partition, but you write that gparted shows it as FAT16. But /dev/hda2
looks fine in the partition table. can you access the filesystem on
/dev/hda2 from linux?
Thomas.
Matteo schrieb:
> Ok this is the result of the command "fdisk -l /dev/hda"
> Disk /dev/hda: 40.0 GB, 40007761920 bytes
> 255 heads, 63 sectors/track, 4864 cylinders
> Units = cilindri of 16065 * 512 = 8225280 bytes
> Dispositivo Boot      Start         End      Blocks   Id  System
> /dev/hda1            2678        3014     2706952+  83  Linux
> /dev/hda2               1        2677    21502971    c  W95 FAT32 (LBA)
> /dev/hda3            3015        4784    14217525   83  Linux
> /dev/hda4            4785        4864      642600    5  Esteso
> /dev/hda5            4785        4864      642568+  82  Linux swap / Solaris
> looking with gparted I have the result that, hda1 is "FAT16", hda2 is "FAT32",
> hda3 is "ext3", hda4 is "exetended", hda5 is "linux swap".
> I created hda1 with FAT16 thinking to resolve the problem, but from the fileio
> example I have always the same error,
> " fsmount: mounting of "/dev/hda1" to "/mnt/hda1" failed: No such file or
> directory " but now hda1 is FAT16 so it could be right for RTEMS, but it isn't.
> Why ?
> Can you help me ?
> Thanks advanced
> MAtteo
> Scrive "Thomas Doerfler (nt)" <Thomas.Doerfler at imd-systems.de>:
> Matteo,
> Matteo schrieb:
>>Ok hda3 is "ext3", but I have a window "FAT" on hda1 and hda2, so I could
> save
>>my file in this partitions?
> yes, this should be possible.
>>But I see from the error message that RTEMS can't mount all my partition
> hda1,2
>>(FAT) for windows and hda3,4 (ext3) for linux.
> can you boot linux on your system, log in as root and send me the output
> of the command   "fdisk -l /dev/hda" ? Maybe the type of your FAT
> partitions is ounknown to RTES or your FAT partitions are located in an
> extended partition (most unlikely).
>>Can you help to save a file in one of this partitions ?
>>Is there any way to save on a "ext3" partitions ?(Because I have to test
> RTEMS
>>on some linux systems and I'm afraid they are all "ext3"!)
> Currently there is no RTEMS support for ext3 filesystems, so sorry, this
> will not work.
> wkr,
> Thomas.
>>Matteo,
>>well, it SHOUDL work, if you have a FAT partition in the primary
>>partition table of your harddisk.
>>You are mentioning havong Linux on hda3, most problable it will use
>>"ext3" as the filesystem, and RTEMS does not know this FS type.
>>When you are running Linux on your system, what kind of output do you
>>get from the command
>>fdisk -l /dev/hda
>>(you have to run this as root).
>>wkr,
>>Thomas.
>>Matteo schrieb:
>>>Ok, like you have suggested I understood the steps to mount the hardisk,
>>but
>>>the problem is that the fileio example doesn't mount my hardisk!
>>>I follow the steps suggest from the fileio.doc but after it asks to me to
>>enter
>>>the partition table of first harddisk ( /dev/hda ) I try to mount the
>>>partitions and I have an error, He says to me
>>>directory "  and so on for hda2,3,4 and for hdc1,2,3,4
>>>Linux partition is on hda3, but the fileio example doesn't mount it !
>>>What's the problem ?
>>>Have you some idea ?
>>>Really Thanks in advance
>>>Matteo
>>>Matteo,
>>>I assume you are working on a standard i386 pc hardware. Have a look at
>>>the "fileio" sample application available in the RTEMS source tree under
>>>"cpukit/testsuites/samples/fileio". You should try to get it working on
>>>your system (it should work from scratch if you got a standard PC system).
>>>Have a look at "fileio.doc", it explains a bit what should work with
>>>this sample program.
>>>In your application, you will have to do the following steps to get
>>>access to your harddisk:
>>>- add the IDE and ATA drivers to your standard driver table (see entries
>>>in fileio/system.h)
>>>- add a rtems_bdbuf_configuration data structure to your system (once
>>>again, see fileio/system.h)
>>>- add a fs_table to your application, which specifies which harddisk
>>>partitions are to be mounted to which mount points (see fileio/
>>>- call the "rtems_ide_part_table_initialize" function after system
>>>startup to read in your harddisk partition table. This call will create
>>>a new device node (/dev/hda1 ...) for each partition available.
>>>- call the "rtems_fsmount" function to mount the partitions to their
>>>respective mount points. Have a look into "libmisc/fsmount" to find out,
>>>how it works.
>>>Then you can access the harddisk partitions at their respective mount
>>>points.
>>>wkr,
>>>Thomas.
>>>Matteo schrieb:
>>>>Hi
>>>>Joe says to me ask you how I can save a file on hard disk? if I have to
>>set
>>>>something in my linux's grub?
>>>>below the previous email sent to Joel.
>>>>Thanks in advance
>>>>Matteo
>>>>Scrive Joel Sherrill <joel.sherrill at oarcorp.com>:
>>>>>Matteo wrote:
>>>>>>Hi
>>>>>>I'm trying to use the fdopen example of the package example-4.6.99.2
> but
>>>it
>>>>>>doesn't works, It doesn't create the file!
>>>>>I could be wrong but I think this one actually was submitted as part of
>>>>>a bug report and
>>>>>the bug may still be outstanding.  It may be fixed.  I just don't
>>>>>remember.  See below for
>>>>>the more likely case.
>>>>>>But I can launch the hello world example and I create some simple posix
>>>>>program
>>>>>>with rtems yet so I think to have configured it well.
>>>>>>So what can be the problem ?
>>>>>>May be when I launch the fdopen example I have to set some particular
>>>>>privilege
>>>>>>in the "grub"(my linux boot loader) to allow it to write on the hard
>>>disk?
>>>>>this
>>>>>>is only my newbye's opinion..
>>>>>Ohh.... if you are doing anything with the hard disk, then there is some
>>>>>filesystem specific
>>>>>configuration to get things right.  The example code is only going to
>>>>>work with the IMFS
>>>>>which is a RAM based filesystem.
>>>>>Ask on the list so someone list Thomas can point you to an example
> setup.
>>>>>>Thanks in advantage
>>>>>>Matteo
>>>IMD Ingenieurbuero fuer Microcomputertechnik
>>>Thomas Doerfler           Herbststrasse 8
>>>D-82178 Puchheim          Germany
>>>email:    Thomas.Doerfler at imd-systems.de
>>>PGP public key available at:
>>>    http://www.imd-systems.de/pgpkey_en.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.5 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFEFb7ZwHyg4bDtfjQRAiXDAJ9FyOb2fWyRGtL9IUbR6gIIHiZ2hQCfaQXO
7CDQa4svlOVs2IJ1jTWtsN0=
=9YWo
-----END PGP SIGNATURE-----
