SV: RTEMS 4.6.4 fails on Cygwin
    Angelo Fraietta
    newsgroups at smartcontroller.com.au
    Tue Mar 14 02:25:16 UTC 2006
Ralf Corsepius wrote:
> On Mon, 2006-03-13 at 16:53 -0600, Joel Sherrill wrote:
>>Ole Hansen wrote:
>>>Hello Joe
>>>Are there any preferences of version of GCC + tools to use for building crossgcc  ??
>>In general, you should use the same version native to build a cross.
> Nonsense - Joel, what makes you say this?
> To build GCC/c and GCC/c++ cross, all you need is a sufficiently
> ANSI-compliant C-compiler and a sufficiently POSIX compliant run-time
> environment.
I found that I needed to first build gcc-3.3.5 and use them to build the
coross tools - that is, on my Linux system anyway. GCC 4.0 would not
build the RTEMS tools.
Furthermore, I was unable to make gcc-3.2.3 on my linux machine, which
is why I used gcc-3.3.5
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.smartcontroller.com.au/~angelo/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
     Bernard of Clairvaux (1090 - 1153)
