Problem to save file on the hard disk! What I have to set to do it ?
    Thomas Doerfler
    Thomas.Doerfler at imd-systems.de
    Thu Mar 16 08:18:01 UTC 2006
Yan,
agreed, you should have an IDE interface in such a machine. You might
verify it in your BIOS page. And I got no idea, what might go wrong with
your interface, sorry.
Yan Luo wrote:
>> Hm, this sounds, as if reading of the partition table hangs. What kind
>> of interface do you have to connect your harddisk? RTEMS currently  only
>> supports a standard IDE interface (no SCSI, no SATA...). And it  asumes,
>> that the harddisk is connected as Master to the primary IDE  interface. I
>> should have mentioned this before :-(
> I am using a pretty old laptop (Compaq, Pentium, no CDROM). I believe
> the hard drive is standard IDE based and on primary master because it
> is "hda" in Debian linux. It would have other device names if it were
> SCSI or other, right?
> I am wondering if "grub" (the boot loader) caused the problems. Both
> Matteo and I use grub. Will grub affect the partition table and
> mounting? Could you tell us the test environment that you run fileio  on
> before, if you don't use grub or lilo?
> Thanks,
> Yan
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler           Herbststrasse 8
D-82178 Puchheim          Germany
email:    Thomas.Doerfler at imd-systems.de
PGP public key available at:
      http://www.imd-systems.de/pgpkey_en.html
