Filio example doesn't run with rtems from the cvs
    Matteo
    matteo.posterli at studenti.unipr.it
    Mon Mar 20 12:50:19 UTC 2006
Hi Karel,
May be I understand the problem;
If I launch fileio.exe token from the builded version of the rtems;
../build-rtems/i386-rtems4.7/c/pc386/testsuite/samples/fileio/fileio.exe
everything works well I can mount my partition.
If I try to compile the same file of the samples I compile without problem but
the fileio example doesn't works!
So the problem is if I try to compile using my gcc version but How it's
possible? I take rtems from the cvs and I compile it so it could be the same If
I take the fileio example and I try to compile only it!
Can you help me ?
Thanks in advantage
Matteo
Scrive Karel Gardas <kgardas at objectsecurity.com>:
> Hi Matteo,
> please test hello world and ticker examples too. You are able to compare
> your actual demo output with expected and find out if your RTEMS is broken
> or not. This will help you with judging what happen in fileio.
> Cheers,
> Karel
> On Mon, 20 Mar 2006, Matteo wrote:
> > Hi Karel,
> > I installed binutils-2.16.1, gcc-4.0.2, newlib-1.13.0 and rtems from the
> cvs but
> > the fileio example doesn't run.
> > I can compile it but when I launch it I have only the message about the
> Console
> > Device and stop.
> > I try to add
> > #define CONFIGURE_INIT_TASK_STACK_SIZE  (100 * RTEMS_MINIMUM_STACK_SIZE)
> > in system.h but the result it's the same .
> > Someone can help me to write a file on my hard disk ?
> > Thanks in advance
> > Matteo
> >> OK, so please do not forget to report if your fileio and other examples
> >> are working as expected and if you are finally able to mount your FAT16
> >> partition.
> >> Cheers,
> >> Karel
> >> On Fri, 17 Mar 2006, Matteo wrote:
> >>> Thanks, you get reason, I forgot to do it
> >>> Matteo
> >> Karel Gardas                  kgardas at objectsecurity.com
> >> ObjectSecurity Ltd.           http://www.objectsecurity.com
