Filio example doesn't run with rtems from the cvs
    Matteo
    matteo.posterli at studenti.unipr.it
    Mon Mar 20 13:34:04 UTC 2006
Ok , I see from ftp://ftp.rtems.com/pub/rtems/4.6.99.2/TOOL_VERSIONS that I'm
using a compatible version of gcc, newlib and binutils (gcc-4.0, newlib-1.13,
binutils-2.16).
Infact using this toolset I can compile correctly rtems and the testsuite and
fileio example works well.
After I take the source code of fileio example and I compiled it and the example
 doesn't works!
How it's possible, I use the same source file, the only difference is that in
the first case the example are compiled automatically with rtems and in the
second case I compiled the source code of the example separately.
Note that I try compile separately the hello and ticker examples  and they works
well, so why fileio doesn't work ?
Thank in advance
Matteo
Scrive Thomas Doerfler <Thomas.Doerfler at imd-systems.de>:
> Matteo,
> for RTEMS, the compiler version, the binutils, the newlib (!) and the
> RTEMS source code version are very closely related. If you take an
> arbitrary GCC version and try to compile RTEMS, it is quite likely that
> you will fail.
> If you look into the "TOOL_VERSION" file located together with the
> released RTEMS source code (like
> ftp://ftp.rtems.com/pub/rtems/4.6.99.2/TOOL_VERSIONS ) you get an exact
> list of tools which are suitable for this version.
> Building your own compiler environment is quite a delicate task, and it
> takes a lot of either time or experience to get it right. It is MUCH
> easier to use the proper packaged toolset from ftp.rtems.com
> So, back to the fileio: I understand you right that you can mount your
> harddisk, when you compiled your fileio.exe with the right toolset? This
> sounds great, at least this is a starting point for your application, I
> think.
> wkr,
> Thomas.
> Matteo wrote:
> > Hi Karel,
> > May be I understand the problem;
> > If I launch fileio.exe token from the builded version of the rtems;
> > ../build-rtems/i386-rtems4.7/c/pc386/testsuite/samples/fileio/fileio.exe
> > everything works well I can mount my partition.
> > If I try to compile the same file of the samples I compile without problem
> but
> > the fileio example doesn't works!
> > So the problem is if I try to compile using my gcc version but How it's
> > possible? I take rtems from the cvs and I compile it so it could be the
> same If
> > I take the fileio example and I try to compile only it!
> > Can you help me ?
> > Thanks in advantage
> > Matteo
> > Scrive Karel Gardas <kgardas at objectsecurity.com>:
> >>Hi Matteo,
> >>please test hello world and ticker examples too. You are able to compare
> >>your actual demo output with expected and find out if your RTEMS is broken
> >>or not. This will help you with judging what happen in fileio.
> >>Cheers,
> >>Karel
> >>On Mon, 20 Mar 2006, Matteo wrote:
> >>>Hi Karel,
> >>>I installed binutils-2.16.1, gcc-4.0.2, newlib-1.13.0 and rtems from the
> >>cvs but
> >>>the fileio example doesn't run.
> >>>I can compile it but when I launch it I have only the message about the
> >>Console
> >>>Device and stop.
> >>>I try to add
> >>>#define CONFIGURE_INIT_TASK_STACK_SIZE  (100 * RTEMS_MINIMUM_STACK_SIZE)
> >>>in system.h but the result it's the same .
> >>>Someone can help me to write a file on my hard disk ?
> >>>Thanks in advance
> >>>Matteo
> >>>>OK, so please do not forget to report if your fileio and other examples
> >>>>are working as expected and if you are finally able to mount your FAT16
> >>>>partition.
> >>>>Cheers,
> >>>>Karel
> >>>>On Fri, 17 Mar 2006, Matteo wrote:
> >>>>>Thanks, you get reason, I forgot to do it
> >>>>>Matteo
> >>>>Karel Gardas                  kgardas at objectsecurity.com
> >>>>ObjectSecurity Ltd.           http://www.objectsecurity.com
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler           Herbststrasse 8
> D-82178 Puchheim          Germany
> email:    Thomas.Doerfler at imd-systems.de
> PGP public key available at:
>       http://www.imd-systems.de/pgpkey_en.html
