Filio example doesn't run with rtems from the cvs
Thomas Doerfler Thomas.Doerfler at imd-systems.de
Mon Mar 20 16:40:32 UTC 2006
Matteo,
have a look at:
http://www.rtems.com/cgi-bin/viewcvs.cgi/~checkout~/rtems/testsuites/samples/fileio/system.h?rev=1.6&content-type=text/plain
you can see the proper things required in system.h, it is important,
that the IDE and the ATA drivers are included (and the IDE driver is
included before the ATA driver). You will also need the bdbuf
configuration. I have seen in your makefile, that you do not include the
semaphore and message queue managers. This might also cause problems,
because the drivers will need message queues and semaphores.
Thomas.
Matteo wrote:
> Hi Thomas,
> the makefile is ;
> #  Makefile
> #  RTEMS_MAKEFILE_PATH is typically set in an environment variable
> EXEC=fileio.exe
> PGM=${ARCH}/$(EXEC)
> # optional managers required
> MANAGERS=io
> # C source names
> CSRCS = init.c
> COBJS_ = $(CSRCS:.c=.o)
> COBJS = $(COBJS_:%=${ARCH}/%)
> # C++ source names
> CXXSRCS =
> CXXOBJS_ = $(CXXSRCS:.cc=.o)
> CXXOBJS = $(CXXOBJS_:%=${ARCH}/%)
> # AS source names
> ASSRCS =
> ASOBJS_ = $(ASSRCS:.s=.o)
> ASOBJS = $(ASOBJS_:%=${ARCH}/%)
> # Libraries
> LIBS = -lrtemsall -lc
> include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
> include $(RTEMS_CUSTOM)
> include $(PROJECT_ROOT)/make/leaf.cfg
> OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
> all:    ${ARCH} $(PGM)
> $(PGM): $(OBJS)
> 	$(make-exe)
> j:
> 	@echo $(CFLAGS_DEBUG_V)
> 	@echo $(RTEMS_USE_GCC272)
> in init.c is included the system.h.
> But I don't see "RTEMS_BSP_HAS_IDE_DRIVER", where and how should I use it ?
> To put like a "#define RTEMS_BSP_HAS_IDE_DRIVER" in system.h or to put it
> someway in the makefile ?
> Thanks in advance
> Matteo
> Scrive Thomas Doerfler <Thomas.Doerfler at imd-systems.de>:
>>Matteo,
>>what where your exact steps, when your compiled fileio separately? Which
>>makefile did you use, did you also copy the "system.h" file? There is a
>>BSP preprocessor define which is vital for "fileio", it is called
>>"RTEMS_BSP_HAS_IDE_DRIVER".
>>wkr,
>>Thomas.
>>Matteo wrote:
>>>Ok , I see from ftp://ftp.rtems.com/pub/rtems/4.6.99.2/TOOL_VERSIONS that
>>I'm
>>>using a compatible version of gcc, newlib and binutils (gcc-4.0,
>>newlib-1.13,
>>>binutils-2.16).
>>>Infact using this toolset I can compile correctly rtems and the testsuite
>>and
>>>fileio example works well.
>>>After I take the source code of fileio example and I compiled it and the
>>example
>>> doesn't works!
>>>How it's possible, I use the same source file, the only difference is that
>>in
>>>the first case the example are compiled automatically with rtems and in
>>the
>>>second case I compiled the source code of the example separately.
>>>Note that I try compile separately the hello and ticker examples  and they
>>works
>>>well, so why fileio doesn't work ?
>>>Thank in advance
>>>Matteo
>>IMD Ingenieurbuero fuer Microcomputertechnik
>>Thomas Doerfler           Herbststrasse 8
>>D-82178 Puchheim          Germany
>>email:    Thomas.Doerfler at imd-systems.de
>>PGP public key available at:
>>      http://www.imd-systems.de/pgpkey_en.html
