Filio example doesn't run with rtems from the cvs
Matteo
matteo.posterli at studenti.unipr.it
Mon Mar 20 19:14:15 UTC 2006
Hi Thomas,
the link is at the same file system.h that I use in the samples fileio that I
try to run, so I think, isn't that the problem.
May be, like you say, I have to adjust my make file but How I can add "the
semaphore and message queue managers"?
Thanks in advance
MAtteo
Scrive Thomas Doerfler <Thomas.Doerfler at imd-systems.de>:
> Matteo,
> have a look at:
http://www.rtems.com/cgi-bin/viewcvs.cgi/~checkout~/rtems/testsuites/samples/fileio/system.h?rev=1.6&content-type=text/plain
> you can see the proper things required in system.h, it is important,
> that the IDE and the ATA drivers are included (and the IDE driver is
> included before the ATA driver). You will also need the bdbuf
> configuration. I have seen in your makefile, that you do not include the
> semaphore and message queue managers. This might also cause problems,
> because the drivers will need message queues and semaphores.
> Thomas.
> Matteo wrote:
> > Hi Thomas,
> > the makefile is ;
> > # Makefile
> > # RTEMS_MAKEFILE_PATH is typically set in an environment variable
> > EXEC=fileio.exe
> > PGM=${ARCH}/$(EXEC)
> > # optional managers required
> > MANAGERS=io
> > # C source names
> > CSRCS = init.c
> > COBJS_ = $(CSRCS:.c=.o)
> > COBJS = $(COBJS_:%=${ARCH}/%)
> > # C++ source names
> > CXXSRCS =
> > CXXOBJS_ = $(CXXSRCS:.cc=.o)
> > CXXOBJS = $(CXXOBJS_:%=${ARCH}/%)
> > # AS source names
> > ASSRCS =
> > ASOBJS_ = $(ASSRCS:.s=.o)
> > ASOBJS = $(ASOBJS_:%=${ARCH}/%)
> > # Libraries
> > LIBS = -lrtemsall -lc
> > include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
> > include $(RTEMS_CUSTOM)
> > include $(PROJECT_ROOT)/make/leaf.cfg
> > OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
> > all: ${ARCH} $(PGM)
> > $(PGM): $(OBJS)
> > $(make-exe)
> > j:
> > @echo $(CFLAGS_DEBUG_V)
> > @echo $(RTEMS_USE_GCC272)
> > in init.c is included the system.h.
> > But I don't see "RTEMS_BSP_HAS_IDE_DRIVER", where and how should I use it
> > To put like a "#define RTEMS_BSP_HAS_IDE_DRIVER" in system.h or to put it
> > someway in the makefile ?
> > Thanks in advance
> > Matteo
> >>Matteo,
> >>what where your exact steps, when your compiled fileio separately? Which
> >>makefile did you use, did you also copy the "system.h" file? There is a
> >>BSP preprocessor define which is vital for "fileio", it is called
> >>"RTEMS_BSP_HAS_IDE_DRIVER".
> >>wkr,
> >>Thomas.
> >>Matteo wrote:
> >>>Ok , I see from ftp://ftp.rtems.com/pub/rtems/4.6.99.2/TOOL_VERSIONS that
> >>I'm
> >>>using a compatible version of gcc, newlib and binutils (gcc-4.0,
> >>newlib-1.13,
> >>>binutils-2.16).
> >>>Infact using this toolset I can compile correctly rtems and the testsuite
> >>and
> >>>fileio example works well.
> >>>After I take the source code of fileio example and I compiled it and the
> >>example
> >>> doesn't works!
> >>>How it's possible, I use the same source file, the only difference is
> that
> >>in
> >>>the first case the example are compiled automatically with rtems and in
> >>the
> >>>second case I compiled the source code of the example separately.
> >>>Note that I try compile separately the hello and ticker examples and
> they
> >>works
> >>>well, so why fileio doesn't work ?
> >>>Thank in advance
> >>>Matteo
> >>IMD Ingenieurbuero fuer Microcomputertechnik
> >>Thomas Doerfler Herbststrasse 8
> >>D-82178 Puchheim Germany
> >>email: Thomas.Doerfler at imd-systems.de
> >>PGP public key available at:
> >> http://www.imd-systems.de/pgpkey_en.html
