rtems_clock_set @ sparc v7 does not work!
Wed May 31 13:08:40 UTC 2006
Grigori Khmyrov wrote:
> Yes, it would be reasonable explanation!
> I use RTEMS 4.0.0 for the sparc BSP
> And 4.6.2 for i386 BSP (which works)
> How can I patch "memory barrier" for version 4.0.0?
> I can not switch easy to the new rtems version because of mkprom support.
If you are using 4.0.0 and having problems, then I really can't begin to
evaluate what is wrong.  That is a very very old version and the gcc you
are using is very likely too old to even trip the memory barrier problem.
Why is mkprom an issue?  There has to be a way to do the equivalent
functionality after a tool upgrade.  Even if you have to use objcopy and
then run the old mkprom.
--joel
> Thank you,
> Grigori
>>> When I set new time at sparc v7 board using rtems_clock_set(
>>> &newTime ) function,
>>> at some point ticks jump back to previous value!?
>>> It does not happen if I use rtems_clock_set twice:
>>> rtems_clock_set
>>> rtems_clock_set
>> What version of RTEMS are you using?  Does it have the "memory
>> barrier" patch?
>> This sounds like the interrupt critical section issue that was
>> addressed by that patch.
>>> I have same code running at i386 processor and rtems_clock_set is
>>> working OK.
>>> Any ideas?
>>> Thank you,
>>> Grigori
