Fwd: [Qemu-devel] qemu 0.8.2 and RTEMS
Jonathan Kalbfeld jonathan.kalbfeld at gmail.com
Mon Nov 13 22:46:45 UTC 2006
Okay, here's what our friends on the QEMU side said...
Has anyone thought about writing a QEMU BSP for RTEMS?  I'm not a very
good programmer..
---------- Forwarded message ----------
Date: Nov 13, 2006 2:33 PM
Subject: Re: [Qemu-devel] qemu 0.8.2 and RTEMS
To: qemu-devel at nongnu.org
On Mon, 2006-11-13 at 14:06 -0800, Jonathan Kalbfeld wrote:
> qemu -isa -nics 1 -n ~joel/qemu-work/qemu/qemu-kit/tunconfig.sh \
>    -macaddr 00:80:7F:22:61:77 -m 4 -serial stdio -fda
> /home/joel/qemu/grub144
> I have this much of a command line which doesn't cause qemu to
> complain but it doesn't work either:
> qemu -net nic,macaddr=00:80:7F:22:61:77,model=ne2k_isa \
>   -m 4 -fda /home/joel/qemu/grub144
    You need to specify a connection method for the nic.  qemu has vlans
now that organize the internal network.  The default qemu uses with no
-net arguments is -net nic,vlan=0 -net user,vlan=0.  This groups a nic
and a connection method (slirp) on vlan 0.  If you want to use tun/tap
networking specify -net tap instead (along with -net nic,...).  Your old
line might look like the below:
qemu -M isapc -net nic,macaddr=00:80:7F:22:61:77 -net
tap,script=~joel/qemu-work/qemu/qemu-kit/tunconfig.sh -m 4 -serial stdio
Although I'm not sure what the old script format looks like - there are
example qemu-ifup scripts about the net.
> The qemu faq mentions using a tunctl program which I don't see.
Please link that page here so it can be reviewed for correctness.
Qemu-devel mailing list
Qemu-devel at nongnu.org
http://lists.nongnu.org/mailman/listinfo/qemu-devel
Jonathan Kalbfeld
+1 323 620 6682
