CVS Updates
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Oct 20 20:10:21 UTC 2006
Hi,
Ralf has committed code to the "rtems-4-7-branch" which updates
the configurery to use the latest versions of automake and autoconf.
Ralf as also committed similar modifications to the CVS Head.
I committed a change to the CVS head which removed the "macro"
directories from cpukit/ and removed the associated configure flag.
I will be starting a build of all configurations to run over the
weekend to verify all of this. I built after committed my macro change
so that should be OK.
My pending queue:
+ ARM BSP rtl22xx
+ Blackfin port merge once Alain emails it. ;>
+ new 4.7 tools with
- new automake/autoconf
- newlib memory leak patch
+ new 4.8 tools with:
- newlib pthread.h with barrier, rwlock, and spinlock
Test reports from the 4.7 branch are encouraged. Once the new tools
are out, it should be time to consider a release image.
--joel
