problems building MinGW powerpc compiler on MinGW host
Mick Davis mickd at goanna.iinet.net.au
Wed Oct 11 03:22:10 UTC 2006
I've built Mingw/Mingw cross compiler for the coldfire.  Just looking at
your build process compared to mine, I can make a couple of suggestions.
I've got the gcc source under a windows root dir. That is, c:\gcc-4.1.1
. Then under msys, I've mounted the dir in etc/fstab with a line;
/gcc-4.1.1 /gcc-4.1.1
This seems to help some of the scripts when unix and windows paths get
confused.
I've also found from the gcc mailing list a couple of patches which seem
to help gcc under msys.  The cppdefault.c.diff is a hack, which you'll
need to modify for your target. It allows you relocate the install,
something which gets broken by the msys build process. They're attached.
avy st wrote:
> Hello all,
> I'm trying to build an poweroc-rtems4.7 compiler, using MinGW32 as both build machine and host machine.  The final purpose is to build the gcc Ada compiler, so I cannot use the pre-built MinGW package available on the RTEMS site.
> I'm using: binutils-2.16.1 with the binutils-2.16.1-rtems-20050816.diff patch
>                gcc-4.1.1 with the gcc-core-4.1.1-rtems-20060626.diff patch
>                newlib-1.14.0 with the newlib-1.14.0-rtems-20060707.diff patch
> binutils built just fine.
> When building gcc, the process failed when compiling source/gcc-4.1.1-2/gcc/libgcc2.c.
> The error log is attached in file error.txt.  The configuration, as well as the build invocation, can be seen in the attached gcc_build_gcc_only script.
> Does anyone have ideas how to solve the problem?  Any help will be greatly appreciated.
> Sincerely
> Avy Strominger
> astrominger at yahoo.com
Mick Davis
Goanna Technologies Pty Ltd
+61 8 9221 1860
"Shock your lizard today!"
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20061011/02df1d33/attachment-0002.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20061011/02df1d33/attachment-0003.bin>
