Loading RTEMS on an MCP750
gregory.menke at gsfc.nasa.gov
Thu Oct 26 02:42:46 UTC 2006
Hi Amalaye,
The easiest way we found was to set up a tftp server on the switch to
which the mcp750 was connected, then configure PPCBug via "niot" so that
the 750 fetches the executable image from the server. Ensure via "env"
(or is it "cfg") that PREP booting is enabled. The output of the RTEMS
link step is a gzip'ed executable with a smart enough bootloader to
config the PCI bus so RTEMS can use the hardware.
The same procedure applies to most any Motorola board with PPCBug I
think, it does apply to the MTX603 series boards as well.
We have considerable experience with these boards, please get in touch
if you need more info.
Regards,
Greg
Amalaye Oyake writes:
> Hello,
> I use a Motorola MCP 750 board. It was not entirely clear on how to load the
> OS onto the board. I presume there is some sort of bootloader utility.
> Thanks,
> * Amalaye Oyake *
> * Flight Software Applications & Data Product Mgmt */\
> * 818.393.7168 work 818.653.4748 cell *||
> * Jet Propulsion Laboratory, Pasadena CA 91109 */||\
