GDB Stubs for PowerPC BSP with old-exceptions
Till Straumann strauman at slac.stanford.edu
Fri Feb 16 17:15:01 UTC 2007
Robert S. Grimes wrote:
> Hi Till,
> I want to use your gdb stubs and (eventually) cexp, but I'm using a new
> BSP for the Virtex-4 PowerPC.  This BSP is based on the gen405, which
> (still) uses the "old exceptions" model.  Sure enough, your agent won't
> compile for my BSP.  So, what would be involved in making it work with
> "old exceptions"?  Or should I instead change the BSP to "new exceptions"?
I think the latter way is the way to go. Hopefully some day
there will be a single model (again). I'm not sure the 'new'
model is necessarily better (I'm not familiar with the 'old' one)
but it is a hassle to have two. I don't have the time to
implement support for the old model ATM (and I'm not
eager to maintain two models), sorry.
Regards
-- Till
> Thanks,
> -Bob
> Joel Sherrill wrote:
>> Nickolay Kolchin wrote:
>>> Hello,
>>> Where I can get GDB with librdbg support? All gdb versions on
>>> ftp.rtems.com (4.18, 5.2) are build for powerpc-rtems, not
>>> powerpc-RTEMS. So, commands from librdbg manual (setrpcmode,
>>> setdaemontype, target rtems) don't work.
>>> Building GDB from sources (5.2.1 with all Patches applied), fails on
>>> configure stage:
>>> Invalid configuration `powerpc-RTEMS': system `RTEMS' not recognized
>>> Unrecognized target system name powerpc-RTEMS.
>>> Afaik, no rgbd patches for GDB 6.x exist.
>>> So, how librdbg can be used?
>> AFAIK librdbg can't be used with a modern gdb.  The internal structure of
>> gdb changed and no one has updated the code.  IMO this means that rdbg
>> is becoming obsolete and you are better off using the standard gdb remote
>> protocol and stubs.
>> Till Straumann has some nice support for gdb with dynamically loaded modules
>> at his site. Google for "Till cexp" and it will turn up.  Maybe Till
>> will add some
>> comments here. :)
>> --joel
>>> Nickolay
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
