MinGW Toolchain
Sven.BIEBAUT at be.thalesgroup.com Sven.BIEBAUT at be.thalesgroup.com
Tue Nov 20 14:42:36 UTC 2007
Hello,
Some 3 weeks ago I underwent a similar experience :)
On the mingw page on source forge you need to look for the automated mingw
installer. When executed this will allow you to select the mingw components
you need.
For the MSYS packages, look for the current releases, not the
latest(technology preview). There you can find an MSYS-1.0.10.exe package.
The DTK can be found under the MSYS supplementary Tools heading, current
release, as a package msysDTK-1.0.1.exe that should be downloadable.
As a precaution, keep the default installation paths :) For the reason of
this statement, you can checkout the "RTEMS autotools installation on mingw"
thread.
HTH,
Sven
> -----Original Message-----
> From: rtems-users-bounces at rtems.org
> [mailto:rtems-users-bounces at rtems.org]On Behalf Of Wolfram Wadepohl
> Sent: 20 November, 2007 14:50
> To: rtems-users at rtems.org
> Subject: MinGW Toolchain
> Hello,
> i'm changing from cywin to mingw. rtems wiki "MinGW Tools for
> Windows" says
> "install MinGW, MSYS and MSYS DTK". so far so good. mingw
> downloads at
> sourceforge list Automated MinGW Installer, MinGW Runtime,
> MinGW Utilities,
>   MSYS Base System, MSYS Supplementary Tools, MSYS System
> Builder. there
> are no simple modules MinGW, MSYS or MSYS DTK. what exactly is needed?
> Schöne Grüße aus Reutlingen
> Wolfram Wadepohl
> Forschung & Entwicklung
> E&K AUTOMATION
> Indumat GmbH & Co. KG
> Siemensstraße 3
> 72766 Reutlingen
> Deutschland
> Tel.  +49 7121 514-289
> Fax   +49 7121 514-299
> eMail Wolfram.Wadepohl at ek-automation.com
>        W.Wadepohl at ieee.org
> WWW   http://www.ek-automation.com
>        http://www.indumat.de
> Diese Nachricht ist keine geschäftliche Mitteilung i. S. des EHUG.
> Bitte senden Sie mir keine Word- oder PowerPoint- (tm
> Microsoft) Anhänge.
> Senden Sie mir einfachen Text, HTML oder PDF.
> Siehe http://www.gnu.org/philosophy/no-word-attachments.de.html
> rtems-users mailing list
> rtems-users at rtems.com
