No acceptable cc found in $PATH
Jalpan Dholakia
jalpan.dholakia at nxp.com
Thu Nov 22 18:45:03 UTC 2007
Hello,
Under development environment Fedora Linux
after bootstrap I ran configure command and also added - -
prefix=/opt/rtems4.7 once configured I have done
make all install
and I stuck with the error
configure: error: no acceptable cc found in $PATH
My development tools are under /opt/rtems-4.7 and I have appended
following in $PATH
/opt/rtems-4.7:/opt/rtems-4.7/bin
after getting this error I have added following path as it has cc1
/opt/rtems-4.7/libexec/gcc/arm-rtems4.7/4.1.1:$PATH
but still getting error and I have also taken care that it is not using cc
of /usr/bin
Which cc is it asking about?
Here with attaching config.log
(See attached file: config.log)
Regards.
URL: <http://lists.rtems.org/pipermail/users/attachments/20071122/314c50c1/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20071122/314c50c1/attachment.obj>
