Jalpan Dholakia wrote: > Hello, > > Under development environment Fedora Linux > > after bootstrap I ran configure command and also added - - > prefix=/opt/rtems4.7 once configured I have done > > make all install > > and I stuck with the error You should re-try the configure with the target option as --target=arm-rtems4.7 Best of luck Paul
