RTEMS autotools installation on mingw
Sven.BIEBAUT at be.thalesgroup.com
Tue Nov 6 13:34:41 UTC 2007
> -----Original Message-----
> From: Chris Johns [mailto:chrisj at rtems.org]
> Sent: 06 November, 2007 10:58
> To: Sven.BIEBAUT at be.thalesgroup.com
> Cc: rtems-users at rtems.org
> Subject: Re: RTEMS autotools installation on mingw
> Sven.BIEBAUT at be.thalesgroup.com wrote:
> > I installed mingw to c:\mingw and msys (and its dtk) to
> c:\mingw\msys.
> That is a little different but that is ok. The installer
> should handle this.
> > How does it try do detect MSYS, maybe that could give me a
> clue as to what is missing on my pc.
> The code is here for MSYS:
http://www.rtems.org/cgi-bin/viewcvs.cgi/rtems/contrib/mingw/msys-path.nsi?r
ev=1.3
> Yeah I know this is strange looking stuff so let me explain
> the process. The
> first failure is 'Function MSYSDetectSilent'. It looks first
> in 'c:\msys\1.0'
> then it looks in the registry under the key at the top of the
> file. The same
> happens for the DTK.
> Do you have the entries in the registry and if so are in they
> correct ?
As the mingw installer does not allow an install only from predownloaded
packages, I copied the whole tree from a previous install over, so indeed
the entries were not there.
> If there is something else please let me know what it is.
> As a work around if you create the keys as expected and set
> the path the
> installer should work.
I moved my msys installation to c:\msys\1.0 and the MSYS mount point error
is gone. However, the installer can still not detect mingw although it is in
c:\MinGW. Is the installer case sensitive ?
I tried changing the name to lower case, but that didn't change anything.
I looked into the mingw-path.nsi, and found out that the strings the
installer looks for do not exist:
HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\MingW
InstallLocation <->
HKLU\Software\Microsoft\Windows\CurrentVersion\Uninstall\mingw32_is1 Ïnno
Setup:App Path"
This probably has to do with the version of the mingw installer ?
If i add manually the HKLM key, the install continues. Is this the problem
you mentioned about the order of the checks (directory first, registry
afterwards ) ?
Thanks a lot for all the help, the installer now completes and I can start
msys to configure and make RTEMS.
> I think I may look at adding to the installer the ability to
> select via a
> dialog box thingy the path to MSYS etc when the installer
> does not find the
> MSYS. This will how-ever not happen for a while.
> Regards
> Chris
