rtems-cvs toolchain working, virtex fix
Nigel Spon nigel at adi.co.nz
Thu Apr 24 02:59:15 UTC 2008
On 24/04/2008, at 12:54 AM, Alan Cudmore wrote:
> I updated my macports database:
> $ sudo port selfupdate
> and now I have the latest version of mpfr and gmp for building GCC
> 4.3.0
> These libraries can be installed by using the command:
> $ sudo port install gmp mpfr
> When configuring the GCC source, you can specify the location where
> macports puts the libraries.
> --with-gmp=/opt/local --with-mpfr=/opt/local
> macports also has autoconf 2.61 and automake 1.10.1
> So OS X 10.4 users can get nearly anything they need by installing
> the packages from macports.
> I will be able to try building on 10.5 soon.
I tried this, but got the same flex error. So I took out the symlinks
and went back to building seperately. I seem to have found the magic
combo: the trick is to configure gmp with
./configure ABI=32
and mpfr with the CFLAGS settings gmp picks, which on my machine gives:
./configure CFLAGS="-m32 -O2 -fomit-frame-pointer -mtune=k8 -march=k8"
The standard make/make install puts the binaries in /usr/local/lib
where the gcc build will find them.
 From there it was reasonably straightforward and I am pleased to
report that I am now building gcc 4.3 successfully and have a working
powerpc toolchain. I have built the virtex BSP, but had to fix a
couple of things: in both libcpu/powerpc/ppc403/console/console405.c
and libcpu/powerpc/ppc403/tty_drv/tty_drv.c
#include "../ictrl/ictrl.h"
should be:
#include "../irq/ictrl.h"
I look forward to being able to develop an up-to-date BSP for the
PPC405...
"Next week, the tale of some English balloonists who ascended to a
height of seven miles in 1862, without washing."
Michael Hamel
ADInstruments Ltd, Dunedin, NZ
