Problems with the debug information and C++
Sebastian Huber
Wed Dec 17 09:40:26 UTC 2008
Hi,
during the change from GCC 4.2.4 to 4.3.2 something happened with the
debug information (example output for PSIM iostream sample):
Version 4.8:
/opt/rtems-4.8/powerpc-rtems4.8/psim/lib/rtems-4.8/tests
powerpc-rtems4.10-objdump -W iostream.exe > /dev/null
powerpc-rtems4.10-objdump: Warning: There is a hole [0x343e6 - 0x343fd]
in .debug_loc section.
Version 4.9:
/opt/rtems-4.9/powerpc-rtems4.9/psim/lib/rtems-4.9/tests
powerpc-rtems4.10-objdump -W cxx_iostream.exe > /dev/null
powerpc-rtems4.10-objdump: Error: Range lists in .debug_info section
aren't in ascending order!
powerpc-rtems4.10-objdump: Warning: There is a hole [0x230 - 0x640] in
.debug_ranges section.
powerpc-rtems4.10-objdump: Warning: There is an overlap [0x730 - 0x230]
in .debug_ranges section.
Version CVS HEAD:
/opt/rtems-4.10/powerpc-rtems4.10/psim/lib/rtems-4.10/tests
There are many more warnings but they differ only in the numbers. The
error and the overlap warning is new in 4.9 and CVS HEAD. I noticed
this also on m68k. Is this something that may cause harm?
Sebastian Huber, Embedded Brains GmbH
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
PGP : Public key available on request
