4.9.0 with shell via telnetd - new telnetd issue?
Fri Dec 19 00:13:22 UTC 2008
Robert S. Grimes wrote:
> However, when I say ugly, this is what I see.
>     Welcome to rtems-4.9.0(PowerPC/Generic (no FPU)/virtex)
>     COPYRIGHT (c) 1989-2008.
>     On-Line Applications Research Corporation (OAR).
>     Login into RTEMS
>     login: rrtteemmss
              ^ shows echo is confused
>     Password:
>     RTEMS SHELL (Ver.1.0-FRC):. Sep 26 2008. 'help' to list commands.
> Note the login response - what I typed was this "rtems<cr>", where "<cr>" is
> the enter key.  While it at first glance looked like local echo is on, notice
> that I only hit the enter key _once_, yet the shell has seen two; the second
> is consumed by the Password prompt.  So what gives?  Seems like something with
> telnetd - how do I fix this?  I'm sure it is something trivial, yet rather
> important...
The shell will echo and the client should not.
What telnet client are you using ?
Regards
