Ada example problems
Dirk Heinrichs dirk.heinrichs at online.de
Tue Dec 23 21:32:34 UTC 2008
Am Dienstag, 23. Dezember 2008 19:38:09 schrieb Web.POP:
> dumpwebpage: linking fails with several errors
I've got the same problem:
i386-rtems4.9-gnatbind -I/opt/i386-rtems4.9/pc686/lib/include/adainclude -
Mgnat_main -x dumpwebpage.ali
i386-rtems4.9-gnatlink dumpwebpage.ali -o dumpwebpage.exe -B/opt/i386-
rtems4.9/pc686/lib/ -specs=bsp_specs -qrtems -mtune=pentiumpro -
DENABLE_UNTAR_ROOT_FILESYSTEM -I. -Dpc686 -Wl,-Ttext,0x00100000 rtems_init.o
FilesystemImage.o
/opt/i386-rtems4.9/pc686/lib/librtemscpu.a(dummy.o):(.data+0x0): multiple
definition of `rtems_libio_number_iops'
rtems_init.o:(.data+0x70): first defined here
/opt/i386-rtems4.9/pc686/lib/librtemscpu.a(dummy.o):(.bss+0x0): multiple
definition of `rtems_telnetd_maximum_ptys'
rtems_init.o:(.bss+0x0): first defined here
/opt/i386-rtems4.9/pc686/lib/librtemscpu.a(dummy.o):(.data+0x4): multiple
definition of `imfs_rq_memfile_bytes_per_block'
rtems_init.o:(.data+0x74): first defined here
/opt/i386-rtems4.9/pc686/lib/librtemscpu.a(dummy.o):(.rodata+0x0): multiple
definition of `configuration_mount_table'
rtems_init.o:(.rodata+0x40): first defined here
/opt/i386-rtems4.9/pc686/lib/librtemscpu.a(dummy.o):(.data+0x8): multiple
definition of `rtems_filesystem_mount_table'
rtems_init.o:(.data+0x78): first defined here
/opt/i386-rtems4.9/pc686/lib/librtemscpu.a(dummy.o):(.rodata+0x10): multiple
definition of `rtems_filesystem_mount_table_size'
rtems_init.o:(.rodata+0x50): first defined here
/opt/i386-rtems4.9/pc686/lib/librtemscpu.a(dummy.o):(.bss+0x4): multiple
definition of `rtems_malloc_statistics_helpers'
rtems_init.o:(.bss+0x4): first defined here
Bye...
	Dirk
Type: application/pgp-signature
Desc: This is a digitally signed message part.
URL: <http://lists.rtems.org/pipermail/users/attachments/20081223/e516d79e/attachment-0001.bin>
