return values of device driver routines
Till Straumann strauman at slac.stanford.edu
Fri Jan 4 23:07:21 UTC 2008
hwulf at et-inf.fho-emden.de wrote:
> Hi there,
> how do the return values work in the RTEMS device driver routines
> (open, close, read, write, ioctl)?
> When I wanted to return the value (-1), do I have to execute "return
> (-1);" or do I have to set a appropriate variable of the argument
> structures (rtems_libio_open_close_args_t, rtems_libio_rw_args_t,
> rtems_libio_ioctl_args_t)?
E.g., for 'open':
If the device file resides in the IMFS filesystem,
open -> libfs/src/imfs/deviceio.c: device_open() ->
sapi/src/ioopen.c:rtems_io_open() -> driver 'open_entry'
rtems_io_open() passes the return value of your driver's 'open_entry'
back to device_open().
device_open() inspects this return value and
a) returns 0 if open_entry returned 0
b) tries to map the return value of open_entry() into an 'errno' by looking
    at the 'errno_assoc' table defined in deviceio.c.
    If the lookup succeeds then errno is set (otherwise it isn't).
    Either way, device_open() returns -1
Unfortunately, the 'open' syscall again maps the return value of
device_open() (which is always either 0 or -1 ) into an 'errno'
so that the 'errno' value set in step b) is eventually lost (looks like
a bug).
This is my quick and dirty 5min. analysis and may be incorrect.
HTH
-- Till
> Thank you very much and kind regards,
>   Hank
> rtems-users mailing list
> rtems-users at rtems.com
